hi all,
I’m a complete noob with cayenne but managed to follow some of the listed code that has been shared in this community. first of all, I’m sorry for my broken English, since I’m not fluent in English.
I’m doing a water monitoring system for rearing tilapia fish. in this project I will be using:
- ph sensor
- ds18b20 temperature sensor
- DHT 22 sensor
- turbidity sensor
- TDS sensor
all of this sensor is working fine when in Arduino but I would like to make use of cayenne to monitor all this sensor.
I managed to connect the ds18b20 sensor and dht22 sensor to raspberry pi and deploy it to the cayenne dashboard. thanks to all the code that has been shared.
I use Arduino UNO for my turbidity sensor and TDS sensor and connect Arduino thru serial USB connection since I can’t connect thru the wifi shield attached to the UNO.
I managed to get connected to my UNO but no widget appears. below is my code:
#define senseInput A1 //Set to A0 as Analog Read
int senseRawValue; //Some variable
float senseTurbidity; //Some floating variable
char username = “xxxxx”;
char password = “xxxxx”;
char clientID = “xxxxxx”;
//Baud rate can be specified by calling Cayenne.begin(username, password, clientID, 9600);
Serial.begin(9600); //Set as serial communication baud rate 9600
Serial.println(" 14CORE | TURBIDITY SENSING ANALOG TEST CODE ");
Serial.println(“Initializing…”);
delay(4000);
senseRawValue = analogRead(senseInput); //Read input raw value fromt the sensor
senseTurbidity = senseRawValue * (5.0 / 1024.0); //Convert analog data from 0 -1024 to voltage 0 - 5v;
Serial.println("TURBIDITY VALUE > "); //Print the output data to the serial
Serial.println(senseTurbidity);
delay(500);
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(1, senseTurbidity);
//Cayenne.luxWrite(2, 700);
the original code for my turbidity sensor in Arduino is below:
void setup(){
delay(4000);
void loop(){
delay(500);
and the code for my TDS is below:
#define TdsSensorPin A3
#define VREF 5.0 // analog reference voltage(Volt) of the ADC
#define SCOUNT 30 // sum of sample point
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0,copyIndex = 0;
float averageVoltage = 0,tdsValue = 0,temperature = 25;
Serial.begin(115200);
pinMode(TdsSensorPin,INPUT);
static unsigned long analogSampleTimepoint = millis();
if(millis()-analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if(analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if(millis()-printTimepoint > 800U)
for(copyIndex=0;copyIndex<SCOUNT;copyIndex++)
analogBufferTemp[copyIndex]= analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient=1.0+0.02*(temperature-25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge=averageVoltage/compensationCoefficient; //temperature compensation
tdsValue=(133.42compensationVolatgecompensationVolatgecompensationVolatge - 255.86compensationVolatgecompensationVolatge + 857.39compensationVolatge)*0.5; //convert voltage value to tds value
//Serial.print(“voltage:”);
//Serial.print(averageVoltage,2);
//Serial.print("V ");
Serial.print(“TDS Value:”);
Serial.print(tdsValue,0);
Serial.println(“ppm”);
int getMedianNum(int bArray, int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i<iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
else
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
my question is how I want to add this code correctly in the cayenne code. I know there must be something wrong with the code that I upload in cayenne since no widget is detected. thank you in advance for your help.
