i m trying to conect my pi with cayenne
with app it take 46 mins nd still showing wait for board to connect
then i try with terminal but it still not connect nd dashboard does not apear
plz reply
@shramik_salgaonkar plzzzz replyyyy
everything is working fine at my end. i just did a fresh install of raspberry pi and it worked. which raspbian are you using?
i instal it from link available at cayenne my pi is wrking fine but when i tried to cnect it with app it shows waiting for devices to coneect for a long time
same problem arise with terminal commands u can see the screen shots
@shramik_salgaonkar sir which method you prefer to connect with… i used both methods and result is same
it shows waiting for device to connect
which app version are you using? and is it an Android or IOS mobile?
Android samsung G core 2
it takes an hour nd still shows waiting message
what is the cayenne app version?
can you PM me your email_id?
@aphfyp how is your project coming along?
sir it will submit next week. my r pi is still not connected to cayene but i resolve the problem by using python script and bring your thing to send all sensor data nd loads on off situation… i also use pi camra in this and on off my camra with cayene widget.
i included auto manual mode and does not use cayenne triger feature… i program a lot for this proj… now im making final pcb of mh proj on eagle autodeskcad…
@adam sir i have used 8 sensors and 6 loads of diffrent power alltogether in this proj… and also doing some image processing stuff using python and pi cam
would love to see your project shared with the community.
