I am a newbie in Quarantineville trying to get my project moving.
I successfully have my PI up and running with a DHT22 connected and showing realtime data to my PC/Phone via MQTTP API and source code available from the DHT22 project on this form from (ADAM).
I am trying to add a IR520 mosfet as a device with PWM GPIO control ?
It looks like the Gate V which is supposed to be 2–4V and trigger at 3.3. via GPIO isn’t correct. It needs 5V to open all the way.
I am able to open the Gate via GPIO but when measuring Voltage on the ouptut vs Input of the mosfet its noticeably lower. PWM functions are working, but you cannot reach Max Current or Voltage with only GPIO 3V on the Gate. This seems to be a common issue with knockoff mosfets.
add a slider to cayenne dashbaord and read the value using
def on_message(message):
if (message.channel == 4) and (message.value == "1"):
#run the PWM python script
OK I have changed the mosfets to BUZ 11 and verified all HW issues, this mosfet triggers easily on 3.3V TTL level and has more than enough current for what I need to accomplish.
I have verified using this using python.
Now I am not sure how to modify the Python script to create the input loop from Cayene UI back to control the GPIO and have the bidirectional feed back
I am clearly not understanding how to tie this back up to Cayenne ?
