Hello to everybody out there…
I want to control a led driver by PWM Signal with a frequency of 1000, but i don’t know how to set it up… the PCA9685 shows up on the dashboard with the temporary widgets, i pinned the one i want to use, and to change the default frequency i changed it in init.py from 50 to 1000.
Is this the right way to do it?
But i don’t think that the wrong frequency is also the reason why the widget always reset immedatly after i did an input? what’s the problem for that and way more important how i can solve it?
thanks for your help
yes, that should work.
what do you mean by it reset immediately ?
immediatly is wrong. if i move the slider it stays there for a few seconds, until the next mqtt message had been send i think, then it goes back to neutral position.
I build my dashboard a few weeks ago with two dht22 sensors which send their data by mqtt, now i added the PCA9685 via ‘Add new’ but did not changed the script with which i connected the dht22’s to the cayenne dashboard. where do i find it to change it or what can i do else to connect the widget with the PWM Pin on the board.
I’m sorry for my bad english and greenhorn questions… learning a lot right now… home automation, linux, english xD
i guess you are familiar with python. You can use https://github.com/myDevicesIoT/Cayenne-MQTT-Python to connect to cayenne and this gives much more freedom.
until now everything worked with copy & paste and things like that… time seems over
thanks for your answer, think i will be back in a few days with a bugy code and the next questions. be curios
