Hi Cayenne. Is there a way for me to reset the value of the sensor (to 0) in the dashboard for an analog sensor . I tried resetting the programmer and refreshing the browser but the value does not change. Thanks in advance.
you can send a 0 value from your code using Cayenne.virtualWrite(VIRTUAL_CHANNEL, 0, "analog_sensor", "null");, so that the analog sensor widget shows a 0on the dashboard.
But this value of 0" is only during startup right? That means once the analog sensors get to work, the dashboard will start to show non-zero values? Thanks again
if you want it to show 0 during the startup then you need to add it in the void setup().
i did not understand what are you to do, can you provide more details about your project?
Whenever I turn on my programmer, there are already values, in the water level sensor and the moisture level sensor (probably the value taken from the last time the device was on). I want this value to be zero every time I first turn it on. This should be 0 since my sensors haven’t started to measure values yet (it’s not yet dipped in the water).
okay. add Cayenne.virtualWrite(VIRTUAL_CHANNEL, 0, "analog_sensor", "null"); in void setup() and it will make the widget value 0.
ok thanks shramik. i will try
shramik just one more thing- the “0” in the code you gave corresponds to the pin number where the analog sensor is connected right? Or is it really a constant “0”. Thanks
0 is the value which you want to send to the analog sensor widget.
ok thanks
Hi Shramik. In the code that you gave me
Cayenne.virtualWrite(VIRTUAL_CHANNEL, 0, “analog_sensor”, “null”)
the “analog sensor”, what does this corresspond to? is it the name of the sensor pin i declared in the #define function? How about “null”? do i need to replace this with something? or is it simply just null?
Here is my code:
Cayenne Button Widget Example
This sketch shows how to set up a Button Widget with Cayenne.
Steps:
- In the Cayenne Dashboard add a new Button Custom Widget.
- Select a virtual channel number for the widget.
- Set the VIRTUAL_CHANNEL value below to virtual channel you selected.
- Attach an output actuator (e.g. an LED) to a digital pin on your Arduino.
- Set the ACTUATOR_PIN value below to the pin number you used when connecting your output actuator.
- Compile and upload this sketch.
- Once the Arduino connects to the Dashboard you can use the widget button to send digital values.
#include <Servo.h>
Servo servo;
char username = “0677f7e0-aa84-11e7-bd7e-3193fab997a8”;
char password = “d02305d9f8700780fd283e65881d59163f4f2529”;
char clientID = “16dd72c0-e1b2-11e8-a254-e163efaadfe8”;
unsigned long lastMillis = 0;
// Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL_TEMP 1
#define SENSOR_PIN_TEMP 1
#define VIRTUAL_CHANNEL_MOISTURE 0
#define SENSOR_PIN_MOISTURE 0
#define VIRTUAL_CHANNEL_WATERLEVEL 2
#define SENSOR_PIN_WATERLEVEL 2
#define VIRTUAL_CHANNEL_SERVO 6
#define ACTUATOR_PIN_SERVO 6
#define VIRTUAL_CHANNEL_PUMP 4
#define ACTUATOR_PIN_PUMP 4
#define VIRTUAL_CHANNEL_MOTOR 8
#define ACTUATOR_PIN_MOTOR 8
#define VIRTUAL_CHANNEL_ALARM 5
#define ACTUATOR_PIN_ALARM 5
// Analog pin the TMP36 is connected to.
const int tmpPin = 1;
// Voltage to the TMP36. For 3v3 Arduinos use 3.3.
const float voltage = 5.0;
TMP36 tmpSensor(tmpPin, voltage);
Servo myservo;
pinMode(SENSOR_PIN_TEMP, INPUT);
pinMode(SENSOR_PIN_MOISTURE, INPUT);
pinMode(SENSOR_PIN_WATERLEVEL, INPUT);
pinMode(ACTUATOR_PIN_SERVO, OUTPUT);
pinMode(ACTUATOR_PIN_PUMP, OUTPUT);
pinMode(ACTUATOR_PIN_MOTOR, OUTPUT);
pinMode(ACTUATOR_PIN_ALARM, OUTPUT);
Cayenne.virtualWrite(VIRTUAL_CHANNEL_TEMP, 0, “SENSOR_PIN_TEMP”, “null”);
Cayenne.virtualWrite(VIRTUAL_CHANNEL_MOISTURE, 0, “SENSOR_PIN_MOISTURE”, “null”);
Cayenne.virtualWrite(VIRTUAL_CHANNEL_WATERLEVEL, 0, “SENSOR_PIN_WATERLEVEL”, “null”);
myservo.attach(6);
myservo.write(0);
if(millis() - lastMillis > 1000) {
lastMillis = millis();
Cayenne.virtualWrite(10, lastMillis);
// This function is for temperature sensor.
CAYENNE_OUT(1)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL_TEMP, tmpSensor.getCelsius());
// To send the temperature in Fahrenheit or Kelvin use the corresponding code below.
//Cayenne.fahrenheitWrite(VIRTUAL_CHANNEL_TEMP, tmpSensor.getFahrenheit());
//Cayenne.kelvinWrite(VIRTUAL_CHANNEL_TEMP, tmpSensor.getKelvin());
// This function is for moisture sensor.
CAYENNE_OUT(0)
Cayenne.virtualWrite(VIRTUAL_CHANNEL_MOISTURE, analogRead(SENSOR_PIN_MOISTURE));
// This function is for water level sensor.
CAYENNE_OUT(2)
Cayenne.virtualWrite(VIRTUAL_CHANNEL_WATERLEVEL, analogRead(SENSOR_PIN_WATERLEVEL));
// This function is called when data is sent from Cayenne(Servo).
CAYENNE_IN(6)
int x= getValue.asInt();
myservo.write(x);
// This function is for pump.
CAYENNE_IN(4)
int value = getValue.asInt();
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL_PUMP, ACTUATOR_PIN_PUMP, value);
digitalWrite(ACTUATOR_PIN_PUMP, value);
// This function is for fan.
CAYENNE_IN(8)
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL_MOTOR, ACTUATOR_PIN_MOTOR, value);
digitalWrite(ACTUATOR_PIN_MOTOR, value);
// This function is for alarm.
CAYENNE_IN(5)
CAYENNE_LOG(“Channel %d, pin %d, value %d”, VIRTUAL_CHANNEL_ALARM, ACTUATOR_PIN_ALARM, value);
digitalWrite(ACTUATOR_PIN_ALARM, value);
I inserted three codes in void setup (), one for moisture sensor, for water level sensor and tem sensor. The value in the dashboard still has not reset to 0. I am sure there is something wrong with what I did. Can you help me find it. Thanks
have a look at this topic Data types for Cayenne MQTT API
