Dear friends: I’m running my temperature datalogger project on dashboard and trying to save data on sd card. The problem is that when WiFi connection drops for whatever reason, my ESP32 doesn’t write to sd.
It would be valuable to have temperature data saved on sd when conectivity stops, but when it occurs the ESP32 keeps trying to connect (a lot of “Network connect failed” on serial monitor) and nothing else happen.
What can I do to go out that loop?
My code is:
// Libraries to get time from NTP Server
#include <WiFi.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
// Libraries for SD card
#include "FS.h"
#include "SD.h"
#include <SPI.h>
//needed for library
#include <CayenneMQTTESP32.h>
#include <DNSServer.h>
#include <WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <OneWire.h>
// Save reading number on RTC memory
RTC_DATA_ATTR int readingID = 0;
String dataMessage;
String dataPath;
String dataPatha;
// Temperature value
float temp;
float temp2;
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUSA 22
#define ONE_WIRE_BUSB 21
#define THRESHOLD1 23 //Threshold for the trigger.
//booleano para definir el trigger
bool sendBelowThreshold = true; //Set to true if the trigger should happen when the data value is below the threshold,
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Variables to save date and time
String formattedDate;
String dayStamp;
String timeStamp;
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWireA(ONE_WIRE_BUSA);
OneWire oneWireB(ONE_WIRE_BUSB);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensorsA(&oneWireA);
DallasTemperature sensorsB(&oneWireB);
char username[] = "XXX";
char password[] = "XXX";
char clientID[] = "XXX";
// Function to get temperature
void getReadings(){
sensorsA.requestTemperatures();
temp = sensorsA.getTempCByIndex(0); // Temperature in Celsius
//temperature = sensors.getTempFByIndex(0); // Temperature in Fahrenheit
Serial.print("Temperature 1: ");
Serial.println(temp);
sensorsB.requestTemperatures();
temp2 = sensorsB.getTempCByIndex(0); // Temperature in Celsius
Serial.print("Temperature 2: ");
Serial.println(temp2);
Serial.begin(115200);
sensorsA.begin();
sensorsB.begin();
Serial.println();
Serial.println();
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset saved settings
//wifiManager.resetSettings();
//set custom ip for portal
//wifiManager.setAPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
//here "ARD3"
//and goes into a blocking loop awaiting configuration
wifiManager.autoConnect("ARD3");
//or use this for auto generated name ESP + ChipID
//wifiManager.autoConnect();
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
// Initialize a NTPClient to get time
timeClient.begin();
// Set offset time in seconds to adjust for your timezone, for example:
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
timeClient.setTimeOffset(-10800);
// Initialize SD card
SD.begin();
if(!SD.begin()) {
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if(cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.println("Initializing SD card...");
if (!SD.begin()) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
// If the iptp3_t1.txt file doesn't exist
// Create a file on the SD card and write the data labels
File file = SD.open(dataPatha);
if(!file) {
Serial.println("File doesn't exist");
Serial.println("Creating file...");
writeFile(SD, dataPatha.c_str(), "Reading ID, Date, Hour, Temp (ºC) \r\n");
else {
Serial.println("File already exists");
file.close();
//trigger para temperaturas. Definir los valores a los que se dispara la alarma en TRIGGER. Si es menor queda en 0, si es mayor o igual va a 1
void sendTriggerValue(int channel, int value, int threshold, bool sendBelowThreshold) {
if (((value < threshold) && !sendBelowThreshold) || ((value >= threshold) && sendBelowThreshold)) {
if (!crossedThreshold) {
Cayenne.virtualWrite(channel, 1, "digital_sensor", "d"); //set trigger two-state widget to 1
crossedThreshold = true;
else if (value < 0) {
Cayenne.virtualWrite(channel, 1, "digital_sensor", "d"); //set trigger two-state widget to 0 //
crossedThreshold = false;
else
Cayenne.virtualWrite(channel, 0, "digital_sensor", "d"); //set trigger two-state widget to 0
CAYENNE_OUT_DEFAULT()
Serial.print("Sensor 1: ");
Serial.println(sensorsA.getTempCByIndex(0));
if (sensorsA.getTempCByIndex(0) != 85 || sensorsA.getTempCByIndex(0) != (-127.0)){
Cayenne.celsiusWrite(1, sensorsA.getTempCByIndex(0));// do stuff if the condition is false
sendTriggerValue(3, sensorsA.getTempCByIndex(0), THRESHOLD1, sendBelowThreshold);
//Cayenne.luxWrite(2, 700);
CAYENNE_OUT(2)
//Cayenne.celsiusWrite(2, Temperature());
Serial.print("Sensor 2: ");
Serial.println(sensorsB.getTempCByIndex(0));
Cayenne.celsiusWrite(2, sensorsB.getTempCByIndex(0));
CAYENNE_IN_DEFAULT()
const unsigned long TiempoenMinutos = 0.5 * 60 * 1000UL;
static unsigned long lastSampleTime = 0 - TiempoenMinutos; // initialize such that a reading is due the first time through loop()
unsigned long now = millis();
if (now - lastSampleTime >= TiempoenMinutos)
lastSampleTime += TiempoenMinutos;
// add code to take temperature reading here
getReadings();
getTimeStamp();
logSDCard();
// Increment readingID on every new reading
readingID++;
// Function to get date and time from NTPClient
void getTimeStamp() {
if(!timeClient.update()) {
timeClient.forceUpdate();
// The formattedDate comes with the following format:
// 2018-05-28T16:00:13Z
// We need to extract date and time
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
// Extract date
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
Serial.println(dayStamp);
// Extract time
timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-1);
Serial.println(timeStamp);
// Write the sensor readings on the SD card
void logSDCard() {
dataPath = String(dayStamp);
String dataPatha = "/data/"+ dataPath + "_t1.csv";
String path = dataPatha;
dataMessage = String(readingID) + "," + String(dayStamp) + "," + String(timeStamp) + "," +
String(temp) + "," + String(temp2) +"\r\n";
Serial.print("Save data: ");
Serial.println(dataMessage);
appendFile(SD, dataPatha.c_str(), dataMessage.c_str());
// Write to the SD card (DON'T MODIFY THIS FUNCTION)
void writeFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file) {
Serial.println("Failed to open file for writing");
return;
if(file.print(message)) {
Serial.println("File written");
} else {
Serial.println("Write failed");
file.close();
// Append data to the SD card (DON'T MODIFY THIS FUNCTION)
void appendFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file) {
Serial.println("Failed to open file for appending");
return;
Serial.println("Message appended");
} else {
Serial.println("Append failed");
file.close();
many thanks in advance for your help
regards
DL
