My code is working well and data are saved in real time in Cayenne.
How to save the same data on SD Card ?
I am using this code and its working.
How to save same data on SD Card ? Can yo help me, please ?
#define CAYENNE_DEBUG
#include “DHT.h”
#define DHTPIN 12
#define DHTTYPE AM2301
DHT dht(DHTPIN, DHTTYPE);
char ssid = “";
char wifiPassword[] = "**”;
char username = “";
char password[] = "";
char clientID[] = "*****************************************”;
unsigned long lastMillis = 0;
Serial.begin(115200);
dht.begin();
if (millis() - lastMillis > 14400000) {
lastMillis = millis();
float humidity = dht.readHumidity();
float temperature = dht.readTemperature();
Cayenne.celsiusWrite(1, temperature);
Cayenne.virtualWrite(2, humidity, "rel_hum", "p");
CAYENNE_IN_DEFAULT()
this is the library you need to use to write data to SD data. https://www.arduino.cc/en/Tutorial/LibraryExamples/ReadWrite
