@shramik_salgaonkar this code is working with cayenne. Can you help me to save the same data on sd card please?
I have tried many thing but its not working.
// This example shows how to connect AM2301/DHT21 to Cayenne using an ESP8266 and send/receive sample data.
#define CAYENNE_DEBUG
#include “DHT.h”
#define DHTPIN 12 // modify to the pin we connected
#define DHTTYPE AM2301 // AM2301
DHT dht(DHTPIN, DHTTYPE);
char ssid = “***";
char wifiPassword[] = "”;
char username = “";
char password[] = "”;
char clientID = “******************************************”;
unsigned long lastMillis = 0;
Serial.begin(115200);
dht.begin();
lastMillis = millis();
float humidity = dht.readHumidity();
float temperature = dht.readTemperature();
Cayenne.celsiusWrite(1, temperature);
Cayenne.virtualWrite(2, humidity, "rel_hum", "p");
CAYENNE_IN_DEFAULT()
