pi@raspberrypi : ~ $ tail -f /var/log/myDevices/cayenne.log
2020-11-06 20:35:13 - myDevices - INFO - Enabled plugins: dict_keys([‘sensehat:0’, ‘sensehat:1’, ‘sensehat:2’, ‘sensehat:3’, ‘sensehat:4’, ‘sensehat:5’])
2020-11-06 20:35:13 - myDevices - INFO - Send system info: [{‘sys:os:name’: ‘raspbian’}, {‘sys:os:version’: ‘10’}, {‘agent:version’: ‘2.0.4.280’}, {‘sys:pwr:reset’: 0}, {‘sys:pwr:halt’: 0}]
2020-11-06 20:35:13 - myDevices - INFO - Connected with result code 0
2020-11-06 20:35:14 - myDevices - INFO - Executing regular download test for network speed
2020-11-06 20:35:14 - myDevices - INFO - Sensors info:
2020-11-06 20:35:14 - myDevices - ERROR - Failed to connect to Sense HAT device
2020-11-06 20:35:14 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 2.3}, {‘sys:cpu;temp’: 56.965}, {‘sys:ram;usage’: 268525568}, {‘sys:storage:/;usage’: 3517501440}, {‘sys:net;ip’: ‘192.168.1.62’}, {‘dev:sensehat:4’: 0}, {‘dev:sensehat:5’: 0.0}] + sys:gpio
2020-11-06 20:35:29 - myDevices - INFO - Sensors info:
2020-11-06 20:35:29 - myDevices - ERROR - Failed to connect to Sense HAT device
2020-11-06 20:35:29 - myDevices - INFO - Send changed data: [{‘sys:cpu;load’: 0.0}, {‘sys:cpu;temp’: 55.504}, {‘sys:ram;usage’: 269221888}, {‘sys:net;speedtest’: 1.8205054451317866}]
