Sense Hat support on Raspberry Pi
run this command and share the log file.
sudo service myDevices restart
tail -f /var/log/myDevices/cayenne.log
pi@raspberrypi:~ $ sudo service myDevices restart
pi@raspberrypi:~ $ tail -f /var/log/myDevices/cayenne.log
2020-07-23 09:51:20 - myDevices - INFO - Sections: ['SenseHAT Temperature', 'SenseHAT Humidity', 'SenseHAT Pressure', 'SenseHAT Accelerometer', 'SenseHAT Digital Actuator', 'SenseHAT Analog Actuator']
2020-07-23 09:51:20 - myDevices - INFO - Creating instance of SenseHAT for SenseHAT Temperature
2020-07-23 09:51:21 - myDevices - INFO - Loaded sections: ['SenseHAT Temperature', 'SenseHAT Pressure', 'SenseHAT Accelerometer', 'SenseHAT Digital Actuator', 'SenseHAT Analog Actuator']
2020-07-23 09:51:21 - myDevices - INFO - Enabled plugins: dict_keys(['sensehat:2', 'sensehat:3', 'sensehat:4', 'sensehat:5'])
2020-07-23 09:51:21 - myDevices - INFO - Send system info: [{'sys:os:name': 'raspbian'}, {'sys:os:version': '10'}, {'agent:version': '2.0.4.280'}, {'sys:pwr:reset': 0}, {'sys:pwr:halt': 0}, {'sys:i2c': 1}, {'sys:spi': 1}, {'sys:uart': 0}, {'sys:1wire': 1}, {'sys:devicetree': 1}]
2020-07-23 09:51:21 - myDevices - INFO - Executing regular download test for network speed
2020-07-23 09:51:22 - myDevices - ERROR - TestDownload:<urlopen error [SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:1056)>
2020-07-23 09:51:22 - myDevices - INFO - Daemon failure handling None
2020-07-23 09:51:22 - myDevices - INFO - Sensors info: []
2020-07-23 09:51:22 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 15.3}, {'sys:cpu;temp': 50.464}, {'sys:ram;usage': 231968768}, {'sys:storage:/;usage': 7600996352}, {'sys:net;ip': '192.168.125.185'}, {'dev:sensehat:2': 98477.2705078125}, {'dev:sensehat:3': [-0.10784799605607986, 0.9640439748764038, -0.23716799914836884]}, {'dev:sensehat:4': 0}, {'dev:sensehat:5': 0.0}] + sys:gpio
2020-07-23 09:51:37 - myDevices - INFO - Sensors info: []
2020-07-23 09:51:37 - myDevices - INFO - Send changed data: [{'sys:cpu;load': 0.2}, {'sys:cpu;temp': 48.312}, {'sys:ram;usage': 232820736}, {'sys:storage:/;usage': 7601000448}, {'dev:sensehat:2': 98472.0458984375}, {'dev:sensehat:3': [-0.10858000069856644, 0.9635559916496277, -0.23765599727630615]}, {'sys:gpio:14;value': 0}]
2020-07-23 09:51:52 - myDevices - INFO - Sensors info: []
2020-07-23 09:51:52 - myDevices - INFO - Send changed data: [{'sys:cpu;temp': 47.774}, {'sys:ram;usage': 232816640}, {'dev:sensehat:2': 98474.0234375}, {'dev:sensehat:3': [-0.10735999792814255, 0.9625799655914307, -0.2378999888896942]}]
can you delete the device and re-add a new one.
everything is looking good now, thanks!
Dont do the same mistake again of adding two widget on same channel.
