Hello!
The humidity widget on the website stores historical values.
In the android application, the humidity widget does not download historical values.
Is this an application error?
Hello!
everything working fine at my end. i see an issue at your end: why are the values on android app showing data with comma?
delete the widget and let it repopulate it. then add it agin.
I removed and then added, but nothing has changed. There are still commas. Wigety I added on the website.
The website is OK.
can you PM me your account details? i will check at my end.
I sent PM.
Hello!
Today I made another attempt. I sent a number 15. On the website after the number 15 there is a dot.
In the android, after the number 15 there is a comma.
Will this problem be solved?
Hello!
I made another test.
I sent temp, c = 20.27 from MQTT.fx.
The value received by the website is correct (with dot 20.27).
The value received by the “IoT MQTT Panel” application is correct (with dot 20.27).
In the Cayenne application, the value received is incorrect (with a comma of 20,27).
I am asking you to correct this error.
Team is checking into your. Will let you know when it is fixed.
Hello!
Do you know when you will fix this error?
Look. In the graph (on the page) there is no historical humidity.
Problem solved. I had a bug in the code. Thank you shramik_salgaonkar.
