Trigger notify problem
I am using a Wemos D1 to monitor the water level in a water tank with a float switch and it works as intended I can watch the data when triggered and have it set to send a notification to two phone numbers when triggered and it sends to the second phone number I added but not the first
what is the format you have added your contact number? is the country code correct?
I entered area code and phone number
can you private message me your email_id used to login into cayenne.
Adding a 1 to the phone number fixed the problem
Thank you
hiii… i also have a problem…I create a triger but sms alert did not recevied… can u help me?
Have you added the correct contact number format ?
yup . i have added correct contact number format. But i recevied sms somtime. sometime it does not work. i delete trigger and again re configure. few minitues working trigger. after few time it agian not working.
thank u very much. i delete old library and re add new library that you have mention. after adding i try to compile it. but errors are oucering. some loop not in the that library scope. what is the solution for it
what are the errors you are getting?
In file included from C:\Users\ITN\Desktop\Final_Project\Final_Project.ino:7:0:
C:\Users\ITN\Documents\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:31:34: fatal error: ESP8266SerialLibrary.h: No such file or directory
#include “ESP8266SerialLibrary.h”
compilation terminated.
exit status 1
Error compiling for board Generic ESP8266 Module.
Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries folder (e.g. MyDocuments\Arduino\libraries\CayenneMQTT\extras\libraries) to compile this example.
  • Mar 5, 2021 12:19:46 AM Trigger ran successfully
  • Mar 5, 2021 12:19:24 AM Trigger ran successfully
  • Mar 5, 2021 12:19:03 AM Trigger ran successfully
But sms and email not recevied to me. plz help me
you will need to delete the device and re-add a new one.
i already done it. But same results.
The library you mention is included but is limited by the number of text messages I receive. some time any msg not recevied
