I have email triggers set up and they have previously been working fine. Had an event occur that ordinarily would have triggered (and the sensor correctly showed the change in state) - but no emails received.
I know triggers have been problematic at times. Is there an issue at the moment - or is it more likely to be my end?
which device are you using? can you check if the trigger counter has incremented.
Cayenne is running on Raspberry Pi. using a generic digital 2 state widget (float switch).
Yes. the trigger counter in incrementing when I manually push the float switch and observe the digital 2 state icon move from 0 state to 1.
can you PM me your email id.
