Hi All
I am having issues compiling the Cayenne ESP8266 WiFi Shield sketch for an Arduino Uno (Not Nano). I have only added in my WiFi details and the Cayenne Authentication Info. Otherwise the code is straight off the website.
Steps:
char ssid[] = "MY_WIFI_NETWORK";
char wifiPassword[] = "MY_WIFI_PASSWORD";
char username[] = "MY_CAYENNE_ASSIGNED_USERNAME";
char password[] = "MY_CAYENNE_ASSIGNED_PASSWORD";
char clientID[] = "MY_CAYENNE_ASSSIGNED_CLIENT_ID";
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
 delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
// Write data to Cayenne here. This example just sends the current uptime in milliseconds on virtual
channel 0.
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
  //Process message here. If there is an error set an error message using getValue.setError(), e.g
  getValue.setError("Error message");
Originally The error code was much longer but after some digging and fixing I have been able to shorten it. I noticed the code " undefined reference to 'ESP8266: " keeps popping up but I have not been able to find any information on it nor probe around to find the issue
C:\Users\Mark\AppData\Local\Temp\cceZ9HMf.ltrans0.ltrans.o: In function `ESP8266Client::stop()':
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:129: undefined reference to `ESP8266::releaseTCP(unsigned char)'
C:\Users\Mark\AppData\Local\Temp\cceZ9HMf.ltrans0.ltrans.o: In function `ESP8266Client::available()':
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:102: undefined reference to `ESP8266::run()'
C:\Users\Mark\AppData\Local\Temp\cceZ9HMf.ltrans0.ltrans.o: In function `ESP8266Client::write(unsigned char const*, unsigned int)':
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:95: undefined reference to `ESP8266::send(unsigned char, unsigned char const*, unsigned long)'
C:\Users\Mark\AppData\Local\Temp\cceZ9HMf.ltrans0.ltrans.o: In function `ESP8266Client::connect(char const*, unsigned int)':
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:88: undefined reference to `ESP8266::createTCP(unsigned char, String, unsigned long)'
C:\Users\Mark\AppData\Local\Temp\cceZ9HMf.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_Network_Test.ino.cpp.o.3220':
<artificial>:(.text.startup+0xb2): undefined reference to `ESP8266::ESP8266(Stream*)'
C:\Users\Mark\AppData\Local\Temp\cceZ9HMf.ltrans0.ltrans.o: In function `connectWiFi':
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:58: undefined reference to `ESP8266::kick()'
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:62: undefined reference to `ESP8266::setEcho(unsigned char)'
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:66: undefined reference to `ESP8266::enableMUX()'
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:69: undefined reference to `ESP8266::setOprToStation(unsigned char, unsigned char)'
C:\Program Files (x86)\Arduino\libraries\Cayenne-MQTT-Arduino-master\src/CayenneMQTTESP8266Shield.h:73: undefined reference to `ESP8266::joinAP(String, String, unsigned char)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
Any info on the issue is greatly appreciated
Mark
