I’m doing my first test with a microcontroller.
Until now I used Cayenne with the RPI.
"#define CAYENNE_PRINT Serial
char ssid = “";
char wifiPassword[] = "”;
char username = “";
char password[] = "”;
char clientID = “***”;
unsigned long lastMillis = 0;
int led=LOW;
pinMode(4, INPUT); // button
pinMode(5, OUTPUT); // relay
if (millis() - lastMillis > 100) {
lastMillis = millis();
if(digitalRead(4)==HIGH && led==LOW)
digitalWrite(5, HIGH);
led=HIGH;
Cayenne.virtualWrite(1,“1”);
while(digitalRead(4)==HIGH)
delay(10);
if(digitalRead(4)==HIGH && led==HIGH)
digitalWrite(5, LOW);
led=LOW;
Cayenne.virtualWrite(1,“0”);
delay(10);
CAYENNE_IN_DEFAULT()
if (request.channel = 1)
String value;
value = (String)getValue.asString();
if (value == "1")
led=HIGH;
else
led=LOW;
Who can help me make the program work?
The LED remains off and I will not do anything by closing the switch
The button is not in the dashboard
After a while the board ends up offline.
Who can help me ?
Please
