Water flow Line Chart
Hello, I’m new on Cayenne i follow a project flow meter, im made mine with a Esp32 and a water flow sensor FS300A.
Problems:
— I want to have a chart with the consume of water by days.
This is my code
Application:
  • Interface water flow sensor with ESP32 board.
Board:
  • ESP32 Dev Module
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h> //Importar a “BlynkSimpleEsp32” library.
//Activa a Communicação MQTT da plataforma Cayenne:
#include <CayenneMQTTESP32.h> //Importar a "CayenneMQTTESP32" library.
//Autenticação da nossa conta na aplicação Cayenne.
char username[] = "";
char password[] = "";
char clientID[] = "";
//Autenticação de acesso à rede Wi-Fi.
char ssid[] = "";//Colocar o nome da rede Wi-Fi.
char pass[] = ""; //Colocar a password do rede Wi-fi.
        //Nota: Colocar "" caso seja uma rede Wi-Fi aberta.
#define SENSOR  21
long currentMillis = 0;
long previousMillis = 0;
int interval = 1000;
boolean ledState = LOW;
float calibrationFactor = 4.5;
volatile byte pulseCount;
byte pulse1Sec = 0;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
void IRAM_ATTR pulseCounter()
  pulseCount++;
  Serial.begin(115200);
  Cayenne.begin(username, password, clientID, ssid, pass);
  pinMode(SENSOR, INPUT_PULLUP);
  pulseCount = 0;
  flowRate = 0.0;
  flowMilliLitres = 0;
  totalMilliLitres = 0;
  previousMillis = 0;
  attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, FALLING);
     //Iniciar a comunicação com a aplicação Cayenne:
  currentMillis = millis();
  if (currentMillis - previousMillis > interval) {
    pulse1Sec = pulseCount;
    pulseCount = 0;
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
    previousMillis = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate / 60) * 1000;
    // Add the millilitres passed in this second to the cumulative total
    totalMilliLitres += flowMilliLitres;
    // Print the flow rate for this second in litres / minute
    Serial.print("Flow rate: ");
    Serial.print(int(flowRate));  // Print the integer part of the variable
    Serial.print("L/min");
    Serial.print("\t");       // Print tab space
    // Print the cumulative total of litres flowed since starting
    Serial.print("Output Liquid Quantity: ");
    Serial.print(totalMilliLitres);
    Serial.print("mL / ");
    Serial.print(totalMilliLitres / 1000);
    Serial.println("L");
void Counter()
  // Increment the pulse counter
  pulseCount++;
CAYENNE_OUT(V0)                                  //Flow rate:
  Cayenne.virtualWrite(V0, flowRate);
CAYENNE_OUT(V1)                                  //Current Liquid Flowing:
  Cayenne.virtualWrite(V1, flowMilliLitres);
CAYENNE_OUT(V2)                                  //Output Liquid Quantity:
  Cayenne.virtualWrite(V2, totalMilliLitres);
use the correct data type and add the unit and type value. Remove the previous widget from the dashboard and new one auto populate.
Hello, i tried I have tried differents types of data but none worked perfectly.
can you share the code with data types?
The full code is in my initial topic and this is the part of cayenne
i dont see any data type over there.
OK my fault i don’t now i do that.
