I am trying to make a chart.
The chart appears but the date is always 1 januari and not the present date,
Therefore no data will be displayed.
Any idea how to use this properly.
I did use the customise button in the settings to set the date. But it does not seem to do anything.
Luc
can you share the code you are using?
#include <ESP8266WiFi.h>
char ssid[] = "XXXXXXXXXXXXX";
char wifiPassword[] = "YYYYYYYYYY";
char username[] = "ZZZZZZZZZZZZZZZZZZZZZZ";
char password[] = "Z)Z)Z)Z)Z)Z)Z)Z)Z)Z)Z)Z)Z)";
char clientID[] = "Z(Z(Z(Z(Z(Z(Z(Z(Z(Z(Z(Z(Z(Z(";
unsigned long lastMillis = 0;
randomSeed(analogRead(0));
CAYENNE_OUT(1) for sending channel 1 data.
CAYENNE_OUT_DEFAULT()
CAYENNE_IN_DEFAULT()
It is just the sample program from your website which I altered to send a random figure between 0 and 100.
The gauges and text fields on my dashboard display everything well. So there is no problem with the upload of data.
Extra info:
If I look at the DATA there is a complete list available. This program has been running for a day so all the data is there.
Luc
For chart to work properly the data you are sending should have the correct data type. So without the entire code i cannot help you much.
Hi there,
This is the complete software.
The only thinbg I altered is that the original version wrote miliseconds to the broker.
i made a random figure between 0 and 100. No further alterations.
You can find this example at your github site:
I just copied the code and filled in random in stead of millseconds.
And as stated the gauges work the chart just does not work
Luc
Have a look at this post and you will come to know what i mean Data types for Cayenne MQTT API
