//#define CAYENNE_DEBUG
#define TRIGGER 13
#define ECHO 12
#define PUMP 14
char ssid = “XXXXXXXXX”;
char wifiPassword = "XXXXXXXXX
char username = “MQTT_USERNAME”;
char password = “MQTT_PASSWORD”;
char clientID = “CLIENT_ID”;
unsigned long lastMillis = 0;
int VIRTUAL_CHANNEL = 0;
pinMode(TRIGGER, OUTPUT);
pinMode(ECHO, INPUT);
pinMode(PUMP, OUTPUT);
pinMode(BUILTIN_LED, OUTPUT);
CAYENNE_OUT_DEFAULT()
long duration, distance;
digitalWrite(TRIGGER, LOW);
delayMicroseconds(2);
digitalWrite(TRIGGER, HIGH);
delayMicroseconds(10);
duration = pulseIn(ECHO, HIGH);
distance = (duration/2) / 29.1;
if (distance >= 150) {
Cayenne.virtualWrite(0, 255);
else {Cayenne.virtualWrite(0,0);
if (distance <= 15) {
digitalWrite(PUMP, LOW);
Cayenne.virtualWrite(2,0);
delay(1000);
else {
if (distance >= 100){
digitalWrite(PUMP, HIGH);
Cayenne.virtualWrite(2,255);
} else {delay(1000) ;
Serial.print(distance);
Serial.println(“Centimeter:”);
Cayenne.virtualWrite(5, distance);
delay(300);
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
if (getValue.asInt() == 1) { // NOTE: Channel = Virtual Pin
else {
