sorry if my english is bad
please help me to solve my project
i use 2 sensor ultrasonic with newping.h
if i use:
#define CAYENNE_DEBUG
#include <NewPing.h>
NewPing ultrasonic (5,4);
char ssid = “vivo1612”;
char wifiPassword = “99999999”;
char username = “0f3d2bb0-fe1b-11e9-84bb-8f71124cfdfb”;
char password = “4f7d89bc3da5581de2a04b1f9750da8430591389”;
char clientID = “0aefc090-0153-11eb-a67f-15e30d90bbf4”;
unsigned long lastMillis = 0;
#define TRIGGER 5
#define ECHO 4
#define VIRTUAL_CHANNEL 1
CAYENNE_OUT(0)
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
CAYENNE_OUT(1)
int US1 = ultrasonic.ping_cm();
Serial.print(“Hasil Sensor 1 :”);
Serial.print(US1);
Serial.println(“cm”);
delay(100);
Cayenne.virtualWrite(1, US1, “prox”, “cm”);
its totally work…
but if i use:
NewPing ultrasonic2 (6,7);
#define TRIGGER 5
#define ECHO 4
#define TRIGGER2 6
#define ECHO2 7
#define VIRTUAL_CHANNEL 2
CAYENNE_OUT(0)
CAYENNE_OUT(1)
Serial.print(US1);
delay(100);
CAYENNE_OUT(2)
int US2 = ultrasonic2.ping_cm();
Serial.print(“Hasil Sensor 2 :”);
Serial.print(US2);
delay(100);
Cayenne.virtualWrite(2, US2, “prox”, “cm”);
itsn’t work
