About This Project
This is yet another example how to integrate (programmable) power switches into Cayenne.
Because I did not work for a few months with Cayenne I had to re-learn some basic again.
One of them, due to the limited program space of the UNO, I wanted to use CAYENNE_IN_DEFAULT().
But how to identify which widget/channel changed → OK: “request.channel” (check).
In principle this project is not earthshaking, hardly a ripple but perhaps it will help a newbie with his first Cayenne project.
General tips for everybody:
- document inside your sketch
- make references to location where to find libraries
What’s Connected
Arduino UNO plus W5100 internet Shield
433 receiver
Triggers & Alerts
None yet
Scheduling
None yet, still missing sunrise/sunset?
Dashboard Screenshots
The sketch
SKETCH NAME: Cayenne_433_MQTT_UNO created/stiched together by WJ4me aka WJ4IoT
Cayenne Button Widget Example
This sketch shows how to set up a Button Widget with Cayenne.
The CayenneMQTTEthernet.h is required to run this sketch. If you have not already done so you can install it from the Arduino IDE Library Manager.
Steps:
1. In the Cayenne Dashboard add a new Button Custom Widget.
2. Select a channel number for the widget. NOW SKETCH WORKS AS FOLLOWS
- For ELRO switches : request.channel <= 10
- For FLAMINGO switches : request.channel > 10
5. Set the ACTUATOR_PIN value below to the pin number you used when connecting your 433 transmmitter.
6. Set the Cayenne authentication info to match the authentication info from the Dashboard.
7. Compile and upload this sketch.
8. Once the Arduino connects to the Dashboard you can use the widget button to send digital values.
#include <CayenneMQTTEthernet.h> // CayenneMQTT version 1.2.0
char username[] = "your username;
char password[] = "your password";
char clientID[] = "your clientid";
// where to connect the data pin of the 433 transmitter
#define ACTUATOR_PIN 7 // INFO: Do not use digital pins 0 or 1 since those conflict with the use of Serial.
// INFO: remark for all next libraries if not in use please disable from sketch to avoid low memory on Arduino UNO + W5100
// for KLIK AAN / KLIK UIT switches (
// #include <RemoteTransmitter.h> //https://bitbucket.org/fuzzillogic/433mhzforarduino/wiki/Home
// KaKuTransmitter kaKuTransmitter(ACTUATOR_PIN); //data-pin 433 on pin 7
// for Flamingo SF-501PWD (among others, the switch need to be learned to listen to the code, read instructions switch how to program them)
// INFO: most of the time put them in the outlet socket and while flashing it can be programmed
#include <NewRemoteTransmitter.h> //library can be found on https://bitbucket.org/fuzzillogic/433mhzforarduino/wiki/Home
NewRemoteTransmitter transmitter(14727168, ACTUATOR_PIN, 260, 3); //values are transmittercode (change?), pin, miliseconds, repeat
// for Elro switches (with dipswitches requires also void Elro(int device, int deviceSwitch))
#include <RCSwitch.h> //using library: https://github.com/sui77/rc-switch (version 2.6.2)
RCSwitch mySwitch = RCSwitch();
Serial.begin(115200);
// elro 433 test
Elro(3, 0);
delay(2000);
Elro(3, 1);
CAYENNE_LOG("CAYENNE_IN_DEFAULT(%u) - %s, actuator: %d, action: %s", request.channel, getValue.getId(), ACTUATOR_PIN, getValue.asString());
if ( request.channel <= 10 ) {
Elro(request.channel, getValue.asInt());
} else {
transmitter.sendUnit(request.channel - 10, !getValue.asInt()); //action is reversed so !
// kaKuTransmitter.sendSignal('B',request.channel, getValue.asInt()); // not checked, no switches
Serial.println(request.channel);
Serial.println(getValue.asInt());
// INFO: the ELRO switch works with dipswitches, this consist in two parts the transmitter part in this example '11111'
// and the device part; the request.channel from is here converted into the correct dipswitch sequence (more efficient programming is possible).
// if you have more than 4/5 switches it is likely you want add the transmitter id into this funtion.
char* elro_id;
//Serial.println(device);
if (device == 1) { elro_id = "10000";}
else if (device == 2) { elro_id = "01000";}
else if (device == 3) { elro_id = "00100";}
else if (device == 4) { elro_id = "00010";
} else { elro_id = "00001";
mySwitch.enableTransmit(ACTUATOR_PIN);
if (deviceSwitch == 1) {
mySwitch.switchOn("11111", elro_id);
//Serial.println(elro_id);
} else { //(deviceSwitch == 0)
mySwitch.switchOff("11111", elro_id);
mySwitch.disableTransmit();
That’s all folks
