Can you do me a favor? I assume you used the motion sensor widget for putting the motion sensor on the dashboard. Delete the widget and add the motion sensor as a ‘Generic Digital Input’ widget and let me know if it shows up in the trigger dropdown?
Hi, What is the exact action required ?
Are you after latch / solid / hold when triggered or just want a pulse ?
I too would recommend a ‘Latch’ input option in future as one tick box along with some other tricks like perhaps a stay high/low for hh:mm:ss when adding Digital Inputs.
As above suggest try just use generic (if there is any difference)
The OP from most of these motion sensors is usually momentary but should be programmable to a certain extend by the sensitivity and delay potentiometers and or links.
Sorry, couldn’t check this out. Having a strange issue where my rpi shows as offline, but I can ssh in, and access wepiopi via the browser. Second time this has happened now. Also reset the pi, router and pc (Saw the other post regarding the pi going offline) Works for a few hours, and then just becomes completely unresponsive.
Edit: I’ll rebuild it after work, and see if I can fix it.
Here we are 7 hours later and all of the sensors I added last night have now populated the drop down list! The original screen grab was done probably 30 minutes after the sensors were added and the one below 7 or so hours later.
Sorry was unable to try earlier… Just removed the Motion Sensor and replaced by a generic digital IO - but as Ian noted above, don’t see it under Triggers yet. Let’s wait…
I just deleted the generic and added the PIR then an F5 to reload the page, didn’t populate the list.
I then deleted the PIR and added the generic back and checked the list, not there, then F5, and it IS there. Set up the trigger and the PIR via a generic input widget triggers the lamp to come on.
It seems to be a solution, albeit a little clumsy.
Hm, very interesting! I’ve already logged out of the portal, but reading Ian’s message, logged in - and it says my Pi is off line. After 5 minutes still off line, though I can ssh into it wihtout problem. So I restarted it, and - surprise surprise, the generig digital IO is there under Triggers!! So what’s was the “kick” - restarting?..
BTW, I’m very frequently having this - the portal shows RPi off line, while I can still ssh into it. Seems I saw some other thread with this, need to add my voice to that too…
Check the PIR sensor module various types and information: Some have a nice sensistivity and ON duration adjustment This one has 5 to 200 second adjustment
