D18B20 - what should i write into the "slave" field
what should i write into the “slave” field when i want to use a D18B20 Temperature Sensor.
Once it was detected automatically but later it doesn`t work well.
Kind regards
Cay
Hi Cay,
The short answer to your question is the DS18B20 address goes in the slave field.
or
Each 1-Wire slave device has a unique, unalterable, factory-programmed, 64-bit ID (identification number), which serves as device address on the 1-Wire bus.
The slave address for a DS18B20 looks like this 28-000006908c5f .
If Cayenne can’t ‘see’ the device you can use the below link to instructions to check to see if the RPi and 18B20 are working together.
Good luck,
Ian
Hi Ian,
thank you for your reply.
That was really helpfull.
kind regards
Cay
Very good to hear!
Thank you for your patience.
-Ian
@cay.kruse
Cay,
I’ve moved this to the ‘helped’ topic. Please let me know if this is not correct.
Ian
