Esp8266 shield and temp probe
Hello, would this code still be usable?
Steps:
#define MEAT_PROBE_PIN 2 //Now we define which analog pin we're going to read our probe from
#define VIRTUAL_PIN V1
#include <ET73.h> // First we must include the ET73 Library found here
char ssid[] = "ssid";
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
	delay(10);
	// Set ESP8266 baud rate
	EspSerial.begin(115200);
	delay(10);
CAYENNE_OUT(VIRTUAL_PIN){
  //When we call the meat probe getTemp_F method, by default the library takes 24 readings at a 10ms interval
  float myTemp = meatProbe.getTemp_F();
  //Print out our results to the serial monitor
  Serial.print("Temp: ");
  Serial.print(myTemp);
  Serial.print(" F\n");
  Cayenne.fahrenheitWrite(VIRTUAL_PIN, myTemp);
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
I keep getting library errors.
fatal error: ESP8266WiFi.h No such file or directory #include <esp8266WiFi.h>
Are you using ESP as shield with arduino mega?
Hello, Iā€™m trying this with a Sparkfun Red Board / Arduino Uno and a Sparkfun esp8266 WiFi shield.
Thanks.
you have to use this code and follow the steps https://github.com/myDevicesIoT/Cayenne-MQTT-Arduino/blob/master/examples/Connections/ESP8266Shield/ESP8266Shield.ino
