Tomorrow i have a presentation.
I start reprogramming my arduino card and I realize that cayenne does not let me access the “sketch” and " Waiting for board to connect…"
    This example shows how to connect to Cayenne using an Ethernet W5100 shield and send/receive sample data .
    1. Set the Cayenne authentication info to match the authentication info from the Dashboard.
    2. Compile and upload the sketch.
    3. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget
    permanent click the plus sign on the widget.
char username[] = "*********************";
char password[] = "*********************";
char clientID[] = "*********************";
	//Cayenne.luxWrite(2, 700);
Thanks God <3
Re, Where is the digital connection ? -
Only virtual pin…?
yes we changed to a new MQTT based library where you can use virtual pins.
I don’t now how to use it… ^^"
I have the night in front of me. Thanks ^^
Lots of code you can re-use on the forums. Use others projects code and slice n’ dice as you need :slight_smile:
Ok, thx
