Arduino due & w5100 shield
Hi all,
I just installed the CayenneMQTTEthernet.h library and added ethernet.h which was missing inside.
I copied this on arduino:
char username[] = "xxx";
char password[] = "xxx";
char clientID[] = "xxx";
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
but can’t connect.
on serial monitor I display: [2
what am I doing wrong ?
add #define CAYENNE_DEBUG in your code and share the output here.
added #define CAYENNE_DEBUG
in serial monitor i can see only : [
I added print serials like this:
Serial.print(β€œ1”);
Serial.print(β€œ2”);
Serial.print(β€œ3”);
Serial.print(β€œ4”);
I only see: 1
Cayenne.begin(username, password, clientID); is blocked
i’m using Arduino 1.6.5
Arduino AVR Board by Arduino version1.6.22
Arduino SAM Boards(32-bits ARM Cortex-M3) verision 1.6.4
RESOLVED
I updated the ethernrt.h library to version 1.1.1 and moved all the libreia files into the CayenneMQTT / scr folder
and added #include <SPI.h>
awesome work and thanks for finding the solution. it will help users with the same issue in future.
