My devices : Arduino Mega 2560 with W5100 ethernet shield
Web Dashboard
this is my code .
Steps:
- Compile and upload the sketch.
- A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
char username[] = “xxxxxxxxxxxxxxxxxxxxxxxxx”;
char password[] = “xxxxxxxxxxxxxxxxxxxxxxxxx”;
char clientID[] = “xxxxxxxxxxxxxxxxxxxxxxxxx”;
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
