Device: Raspberry Pi Zero W with SenseHat
Dashboard: Android & Web
Hello guys, my problem is that since friday, when I make a get Request to https://platform.mydevices.com/v1.1/telemetry/a27250a0-7f76-11e9-ace6-4345fcc6b81e/sensors/842023e0-7f79-11e9-b4eb-6bf2c2412b24/summaries?type=latest with the bearer Token as usual, it’s responding with a 500 server error status, and before friday it was responding 200 ok with the sensor values. What can I do? thank you so much in advance.
we are looking into the issue, will let you know when it is fixed.
Thank you so much for your response, I’ll be waiting for the fix.
Should be fixed now. can you give it a try and let me know.
Are we currently with the same problem?
we are looking into the issue.
@inti.adq.001 can you check now?
Now it works correctly. Can you know what the fault is? Thank you very much and best regards
some issue with on our backend side.
