Pi3 32GB B+
web on windows 10
cant connect rpi to dashboard/cayenne, it will not update any of the dashboard items then when I try to connect the sensors and ADC i am using it will ‘session time out’ for sensors and the ADC wont let me choose device and connect.
I have been following the instructional on Pi My life up
that -3 error is “Temporary failure in name resolution” which suggests a possible problem with your DNS server. you might try pinging google.com and see if that works. If not you need to fix their DNS settings. If it does work you could try nslookup of mqtt.mydevices.com and see if it’s just our server you are having issues with.
So pinging google and bing gives me a request timed out but pinging the RPi is successful. My next step is to fix my computer’s DNS server then and the issue is getting from my computer+rpi to cayenne dashboard?
