Hello!
So i’m just getting started with Cayenne and I’m experiencing the error that other users are where the default Core temperature widget does not track data over time. I wanted to try recreating that widget as a line chart so i deleted the default temperature widget and now I can’t figure out how to add it back in. When you look at the default core temp widget it lists the channel as “sys:cpu;temp” but I can’t seem to add any new widgets that reference that channel.
Any ideas on how to use the RPi core temperature in a line chart or manually re add it as a temperature reading?
