When i used button to turn off and on loads sometime button widget chnge status without being activated. can someone solve this issue?
second issue is when i turn off or on a button it take a long time to chnge status… is it issue of my internet speed?
which device are you using? raspberry or arduino.
are you using cayenne web dashboard or cayenne app (IOS or android)?
bring your own thing
mqtt python
i send data through my python code from my r.pi
i have used web dashboard
can you share the code you are using?
My code is too long and in .py format i will convert it into .txt formate and then send it to you
without the code, i can’t help you much.
