I am using an ESP8266 NodeMCU 1.0, the Vivaldi Web Browser and the Cayenne Android App
Buttons do not work reliably, they have spinning circles that don’t go away, or pressing a button does not trigger the action it should, This happens both in the website and the Android App.
The code is a slightly modified version of the Cayenne ESP8266 Example
#define CAYENNE_DEBUG
char ssid[] = "A*** ****";
char wifiPassword[] = "A********";
char username[] = "1d02c5b0-96fe-11e7-a5d9-************";
char password[] = "fe786648aa9a1ce8ba8ade1539cf4bf92*******";
char clientID[] = "53797190-f5be-11e9-84bb-8f711*******";
unsigned long lastMillis = 0;
pinMode(5, OUTPUT);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN(5)
digitalWrite(5, getValue.asInt());
