Triggers not working /have to restart app ALWAYS
As the title says, the triggers won’t work (smartphone side - from pc browser ok)
I always need to restart the app everytime I need to control a relay /switch. The icon animates but nothing happens. Then I restart the app and it works. It’s quite frustrating
#define CAYENNE_DEBUG
#include <Adafruit_BMP085_U.h>
#include <SimpleTimer.h>
#include <SPI.h>
//BUTTON declarations
SimpleTimer timer;
const int buttonPin = D8;  // The number of the Pushbutton pin
int buttonState = 0;  // Variable for reading the pushbutton status
long previousMillis = 0;        // will store last time LED was updated
long interval = 3000;           // interval at which to blink (milliseconds)
long currentValue;
float Dtemp;
char ssid[] = "";
char wifiPassword[] = "";
//ALARM RELAY
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN D2 // This button opens connection on the alarm remote control
//BIG GATE GATE RELAY
#define VIRTUAL_CHANNEL 3
#define ACTUATOR_PIN D3 // This button opens connection on the garage gate remote control
unsigned long lastMillis = 0;
  Serial.begin(74880);
  timer.setInterval(1200L, emergencybtn);
  //SETUP WINDOW DOOR AS HIGH (default locked)
  digitalWrite(D5, HIGH);
  pinMode(D5, OUTPUT);
  //SETUP ALARM AS HIGH (default not pressed)
  digitalWrite(D2, HIGH);
  pinMode(D2, OUTPUT);
        //SETUP BIG GATE AS HIGH (default  not pressed)
  digitalWrite(D3, HIGH);
  pinMode(D3, OUTPUT);
          timer.run();
          Serial.print("   Online   ");
void emergencybtn()
   //REDBUTTON EMERGENCY
   previousMillis = millis();
   // read the state of the pushbutton value:
   buttonState = digitalRead(buttonPin);
   //The button is pushed
    while (buttonState == HIGH)
       Serial.println(buttonState);
     currentValue = millis() - previousMillis;
     if (currentValue > interval)  //If pushbutton is over 7 secs, let someone in
       // save the last time relays has been turned on
       digitalWrite(D5, LOW);      //opendoor
       delay(2000);     //give time to turn the handle and open the door
      digitalWrite(D5, HIGH);    //close it
  yield();
// DOOR RELAY   This function is called when data is sent from Cayenne.
CAYENNE_IN(1)
  // Mosfet cut current to open door
  if (getValue.asInt() == 0) {
    delay(2200);
  else {
// ALARM RELAY This function is called when data is sent from Cayenne.
CAYENNE_IN(2)
  // Needs almost 1 sec press to activate/deactivate remote control.
    digitalWrite(D2, LOW);
    delay(800);
  else {
// AUTOMATIC PORCH GATE RELAY This function is called when data is sent from Cayenne.
CAYENNE_IN(3)
  // Needs almost 2 sec press to activate/deactivate remote control
    digitalWrite(D3, LOW);
    delay(1900);
  else {
CAYENNE_OUT (13)
we are looking into this issue.
Did a rollback to 1.5.2 and it seems ok
Seems that something happened between 1.5.2 and 1.5.3
thanks for the details.
