Elsys ELT-1 TTN LoRa -
Web
Dashbpoard works with every Other Temperature (but not this one) as it uses a blue icon in the Left hand Menu, but strangely it uses a puple Temp icon in its device overrview page -
tried to drag Elsys ELT-1 ‘Ext. Temperature’ onto dashboard (it works for all other devices) but not this one. It was the 1st device in the list and the first element in the device (if that’s any help)
I also noticed that when I am on the ELT-1 device overview page
The Guage Ect. Temp Value is showing a good reading 19.2C yet when I then click on the trend icon on this guage it says no data available regardless which time scxale I selexct {m h d w…}
