Device & model you are using - Raspberry Pi Zero W running Buster reading a temperature sensor
What dashboard are you using? iOS iPhone and iPad
Please describe the bug / issue as detailed as possible. The dashboard had stopped showing temperature changes. Decided to remove and reinstate device. Remove worked OK, or seemed to. Adding again never seems to complete and leaves various files behind.
pi@DDhomepi3:~ $ ls
cayenne.err Dropbox-Uploader Pictures rpi_h2e8qu8755.sh Videos
cayenne.out Music Programs rpi_kgkseu3t7y.sh
Desktop myDevices Public rpi_tsz2se4ei1.sh
Documents myDevices.tar.gz python_games Scripts
Downloads oldconffiles RPi_Cam_Web_Interface Templates
I tried running setup.sh from the myDevices folder and got many lines of output that looked good, but then some I cannot fully recall about “not authorised”.
Is there some action I can take to clean up and start again?
PS - I am now remote from the device so I can only access it via VNC and terminal via that. Ideally I need actions I can carry out by that route.
on your pi terminal /etc/myDevices/uninstall/uninstall.sh to uninstall pi agent. Next open cayenne dashboard on a web browser and navigate to Add new ---> Devices/widgets ---> raspberry pi from the option 2 run the lines in the pi terminal. this will install the cayenne pi agent on to your raspberry pi. if there are any issue reported while installing in the pi terminal then share it here.
