Can't add DevEUI
    HTCC-AB02S
    Web
    I can’t add a DevEUI to the devices as it says conflict
@jolcese HTCC-AB02S is not supported on cayenne.
Hi Shramik,
Thanks for your response.
I’m not sure what do you mean it’s not supported as I have it running and reporting location on Cayenne.
What happened is that that I added and remove the chip’s hardware DevEUI a few times and I can no longer add it.
But I’m now generating a “software” DevEUI from the device and it’s reporting the proper GPS location.
I guess somewhere in the system the original/hardware DevEUI is store even when I deleted the device and now it’s not letting me re-add it. Is that possible?
Thanks again
Jose
