Can't connect MKr1000
Ive copied the example code to connect mkr1000: followed instructions exactly but my device is still showing offline.
I have double checked the device code etc. and network password etc are all correct.
Once connected im trying to add several gas sensors and soil moisture sensors etc for a garden project…
Please help!!
add this at the top of your code and share the serial monitor output #define CAYENNE_DEBUG
You mentioned your device is not getting connected. can you share the code you are using.
#include <CayenneMQTTMKR1000.h>
/* WiFi network info.
char ssid[] = "";
char wifiPassword[] = "";
char ssid[] = "";
char username[] = "----";
char password[] = "";
char clientID[] = "----";
CAYENNE_OUT_DEFAULT()
 // Cayenne.virtualWrite(0, millis());
  Cayenne.celsiusWrite(1, 22.0);
  //Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
serial monitor output?
ive shared the serial monitor line of code and there’s nothing showing on the serial monitor… is that normal?
is the baud rate set to 9600?
yes its set to 9600.
is this the code you are running? i do not see #define CAYENNE_DEBUG added in the code.
char ssid = “TANGOBAR”;
char wifiPassword = “BARTANGO2019”;
char ssid = “Jay1”;
char wifiPassword = “password1”;
char username = “0fdad8c0-a94c-11e9-be3b-372b0d2759ae”;
char password = “640293b3e1c44acf1b959acd4fb182e41c0c41e1”;
char clientID = “055bc950-a950-11e9-be3b-372b0d2759ae”;
Can you amend the code ive sent and paste it so i can test please?? Obviously using my credentials…etc…
Thank you
Run the below code and check if you get any output in the serial monitor.
char ssid = “Jay1”;
char username = "0fdad8c0-a94c-11e9-be3b-372b0d2759ae";
char password = "640293b3e1c44acf1b959acd4fb182e41c0c41e1";
char clientID = "055bc950-a950-11e9-be3b-372b0d2759ae";
Serial.println("Starting");
Serial.println("Finished");
[//Cayenne.luxWrite](https://cayenne.luxwrite/)(2, 700);
[//Cayenne.virtualWrite](https://cayenne.virtualwrite/)(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
hi,
now im getting the following error code?
stray ‘\342’ in program
delete all and replace them with "
still nothing showing on serial monitor :frowning:
is the code atleast uploading on your MKR1000?
yes its successfully uploading to mkr1000
Do you get an output of this at least?
Serial.println("setup");
Serial.println("loop");
delay("5000");
yes “loop” is coming up
can you join me on http://slack.mydevices.com/
trying to… for some reason the confirmation email is taking some time reaching me
