I have been working on my IoT project and using cayenne as a cloud. I have been facing issues connecting my esp8266 module to cayenne. Technically it should redirect me to cayenne once i upload my code into the module but it dint redirect even though i uploaded the code in the module. I put the exact credentials as given to me in my code and still it dint work. please help me on it asap. would be grateful for the help
Below i have pasted my code for your reference
#include <ESP8266WiFi.h>
#include <DHT.h>
#include <Adafruit_NeoPixel.h>
#ifdef AVR
#include <avr/power.h>
#endif
#define DHTPIN 4 // setting dht11 pin
#define DHTTYPE DHT11// setting type of the dht
#define PIN D5 // neopixel pin conected to d5
#define NUMPIXELS 12 // number of leds in neopixel ring
#define buzzer D7// set buzzer pin
DHT dht(DHTPIN, DHTTYPE);// object for dht11
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);// object for neopixel
char ssid = “”;
char password = “”;
char username = “2028fbc0-c42d-11e9…”;
char mqtt_password = “7f6f083633898…”;
char client_id = “61cae4d0-c…”;
const int LDRpin = A0;// ldr pin
const int PIRpin = D0;// pir pin
int LDRval = 0;// for reading ldr value
int PIRval = 0;// for reading pir value
int temp;// for reading temperature value from dht11
int hum;// for reading humidity value from dht11
int r,g,b;// variables for storing red green and blue led mix values
int Cmode;// variable for storing security mode activate or deactivate
int TURN;// variable for manuale mode
int SAFE_MODE;// variable for false safe mode
pinM
hum = dht.readHumidity();// storing humidity value to hum variable
temp = dht.readTemperature();//storing temperature value to temp variable
LDRval = analogRead(LDRpin);// read and store ldr value
PIRval = digitalRead(PIRpin); // read and store pir value
Serial.println(PIRval);
// send all sensor values to cayenne
Cayenne.virtualWrite(0,temp);
Cayenne.virtualWrite(1,hum);
Cayenne.virtualWrite(2,LDRval);
Cayenne.virtualWrite(3,PIRval);
// checking temperature or humidity is in dangerous level
if(hum>85&&hum<15){
digitalWrite(buzzer,HIGH);
if(temp>40&&temp<10)
// checking false safe mode
if(SAFE_MODE==1)
digitalWrite(buzzer,LOW);
void setColor(int red,int green,int blue)
for(int i =0;i<=NUMPIXELS;i++)// set every led into the color
pixels.setPixelColor(i,pixels.Color(red,green,blue));// seting color neopixel
pixels.show();// activate neopixel
void setLight()// checking manual mode active or not
if(TURN==1)
manual();
else
if(PIRval>0)
setColor(r,g,b);
else if(LDRval<30)
setColor(r,g,b);
else if(PIRval<1&&LDRval>10)
setColor(0,0,0);
void buglerMode()// bugler mode’s function
if(SAFE_MODE==1)
if(PIRval>0)
Serial.println(“bugler on”);
void manual()// manual mod’s function
setColor(r,g,b);
//recieve values from cayenne
CAYENNE_IN(4)
r= getValue.asInt();// recieve red value for neopixel from cayenne
CAYENNE_IN(5)
g= getValue.asInt();// recieve green value for neopixel from cayenne
CAYENNE_IN(6)
b= getValue.asInt();// recieve blue value for neopixel from cayenne
CAYENNE_IN(7)
Cmode =getValue.asInt();// recieve commands for security mode
Serial.println(Cmode);
CAYENNE_IN(8)
TURN = getValue.asInt();// recieve commands for manual mode
CAYENNE_IN(9)
SAFE_MODE = getValue.asInt();// recieve commands for false safe
