How can i monitor am2301 (temp. and hum. sensor) data with Cayenne and to save data on sd card ?
Are you using arduino or raspberry pi?
I am using esp8266
here is an example to connect it to arduino Cayenne-MQTT-Arduino/DHT.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub
for esp8266 you need to combine the above code into this Cayenne-MQTT-Arduino/ESP8266.ino at master · myDevicesIoT/Cayenne-MQTT-Arduino · GitHub
Dear,
Will sensor data be saved on sd card?
Can you help me with the code please ?
I cant understand how to combine the code.
Waiting for your reply.
Thanka a lot,
But using this code i can only save data on sd card.
I have another problem, i want to save data on sd card and on Cayenne.
Can you me with code please ?
here is how to do it. Did you atleast try it out?
No, because i dont know how to combine these two codes. This is the problem.
I am using this code to show temperature and humidity on dashboard. And i want to save same data on sd card.
Can you help me ?
//#define CAYENNE_DEBUG
#include “DHT.h”
#define DHTPIN 12 // modify to the pin we connected
#define DHTTYPE AM2301 // AM2301
DHT dht(DHTPIN, DHTTYPE);
char ssid = “*******************”;
char wifiPassword = “**************”;
char username = “";
char password[] = "";
char clientID[] = "*****************************”;
unsigned long lastMillis = 0;
dht.begin();
lastMillis = millis();
float humidity = dht.readHumidity();
float temperature = dht.readTemperature();
Cayenne.celsiusWrite(1, temperature);
Cayenne.virtualWrite(2, humidity, "rel_hum", "p");
CAYENNE_IN_DEFAULT()
then you might need to learn some basic first https://www.arduino.cc/en/Tutorial/HomePage?from=Main.Tutorials
Can you help me ?
#include “DHT.h”
char username = “ ";
char password = “ ”;
char clientID = " *****************************”;
dht.begin();
Do you have a SD card module?
yes
#include “DHT.h”
#include <SD.h>
#define CS_PIN D8;
char username = “xx xx";
char password = "xxxx";
char clientID = "xxxx”;
Serial.print("Initializing SD card...");
if (!SD.begin(CS_PIN)) {
Serial.println("initialization failed. Things to check:");
Serial.println("1. is a card inserted?");
Serial.println("2. is your wiring correct?");
Serial.println("3. did you change the chipSelect pin to match your shield or module?");
Serial.println("Note: press reset or reopen this serial monitor after fixing your issue!");
while (1);
Serial.println("initialization done.");
dht.begin();
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.print(temperature);
dataFile.print(" | ");
myFile.println(humidity);
// close the file:
myFile.close();
Serial.println("done.");
} else {
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
I have used this code, but this message is shown in my dispay:
macro “CAYENNE_IN_DEFAULT” passed 1 arguments, but takes just 0.
Why is happening this ?
you can remove the entire function.
Sir,
this message is shown:
myfile is not declared in this scope.
dataFile is not declared in this scope
How to declare it ?
Do i need to create .txt file ?
#include “DHT.h”
#include <SD.h>
#define CS_PIN D8;
File myFile;
while (1);
dht.begin();
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
myFile.print(" | ");
// close the file:
myFile.close();
} else {
Sir,
Its the same code. Its not working.
i dont think so it is the same code. do you know coding then please do it.
