Using Ardunio Uno and Web desktop.
It appears when using the “details & chart” on a value widget the minimum is zero.
On a “line chart” widget it is OK.
I didn’t find a way to set the scale. We get colder than that.
John
can you private message me your cayenne account id to which this device is associated. so that i cab have a look at the issue.
Shramik,
Somebody fix it already? Today it worked as it should.
I’ll get back to you if or when it fails again.
John
I guess the issue was never present.
