After updating the iOS application to version 2.3.2, the buttons stopped working. (reboot, shutdown, etc)
we are looking into this issue. will update once we an update for this.
Tha same problem happened with me
we have a fix for this issue and will have a new build release by end of this week.
Thank you very much for your interests in my problem,
We are waiting for the new release
@ahed.albadin @Alex_Gorr can you update to new app version and try using the actuator.
Actuators earned, but do not work correctly. The command to turn on is executed, but the command to turn off is not.
@Alex_Gorr can you direct message me your email_id.
Thanks, I’ve updated the app and it works now
Can you add mobile notification to sensors, not just a message of an email.
For example when a digital sensor activate the mobile make sound.
we dont support this but you can send a SMS notification to your mobile.
How are you, I have problem when I open the app and press a button, the button will not response and it keeps refreshing, until I restart the app and it will works.
Do you a solution?
we have a fix for this issue and will have an update in upcoming days.
Hello i have the same problem in Android app.
or is this fix just for iOS? thanks.
Was this fixed for IOS version v2.3.3… I still have the same issue. Push buttons locking up in the app…
no. will have it fixed in next update.
I wrote a review recently regarding my concerns. Some apps are still not available in Android devices. Also some control are not functioning well in iOS. Check below snapshot.
trigger also has an issue. sometime it’s working sometime it’s not. Lately, I’ve created another trigger but is not working at all. The bulb as shown above is active even though the LDR value already above 40.
the tank widget is not yet support on mobile platform.
regarding your IOS issue can you provide more details?
can you PM me your email_id so i can look into your issue.
The same problem
I’ve updated the app and the buttons keep refreshing.
Im using the android app
Please help
is it when you keep the app in background? try closing and restarting it again.
