Hi, i am working on an air and sound pollution monitoring system using Cayenne and i need help converting the values from the sensors to ppm and db respectively.
which sensor are you using?
Am using MQ135 gas sensor and Microphone Sound Sensor
do you have a code to interface with arduino (without cayenne code)?
Yes, this is for the Gas sensor
#include <MQ135.h>
MQ135 gasSensor = MQ135(A1);
int ppm = gasSensor.getPPM();
Serial.begin (9600);
void loop ()
float rzero = gasSensor.getRZero();
float ppm = gasSensor.getPPM();
Serial.println(ppm);
delay (1000);
Using this you are getting the correct sensor reading?
Which device along with your arduino are you using to connect to internet?
yes i am. I have connected the arduino to a raspberry for internet connection.
I get the correct readings but when i open my Cayenne dashboard, i dont get the same values on the widget
can you share the code used for this?
Here it is ;
#include <MQ135.h>
#define VIRTUAL_CHANNEL 1
#define VIR_CHANNEL 2
int soundValue;
int db;
float ppm;
char PPM;
char DB;
MQ135 gasSensor = MQ135(1);
char username[] = "----";
char password[] = "";
char clientID[] = "----";
//Baud rate can be specified by calling Cayenne.begin(username, password, clientID, 9600);
soundValue=analogRead (2);
db=(soundValue+83.2073)/11.003;
CAYENNE_OUT(VIRTUAL_CHANNEL)
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(1));
Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(ppm), "PPM" );
//Cayenne.luxWrite(2, 700);
CAYENNE_OUT(VIR_CHANNEL)
Cayenne.virtualWrite(VIR_CHANNEL, analogRead(db), "DB");
CAYENNE_IN(1)
I have made the changes to your code. have a look at the data types Data types for Cayenne MQTT API
#include <MQ135.h>
int soundValue;
int db;
float ppm;
char PPM;
char DB;
char username = “4fb17570-521d-11e9-86b5-4fe3d2557533”;
char password = “70c88dc86d5140d9893866e251ab22d3396fe3c5”;
char clientID = “89b57c10-782b-11e9-beb3-736c9e4bf7d0”;
CAYENNE_OUT_DEFAULT()
Cayenne.virtualWrite(1, db, "analog_sensor", "null");
Cayenne.virtualWrite(2, rzero, "co2", "ppm" );
Cayenne.virtualWrite(3, ppm, "co2", "ppm" );
Thank you very much, i modified your a bit and it works perfectly.
One last thing, my sms alert doesnt work but the email alert does, is this because of my region?
Most likely. If you are outside the US you must include the country code.
Yes i already tried that but ill keep trying
which country are you from ?
Ghana
the contact number should be starting with +233
Ok
Hi Shramik, i dont know if you can help me with this but i fixed a 3.5 inch touchscreen to my raspberry pi to allow me use Cayenne website on it but when i go to the Cayenne website and log in, it tells me to download the Cayenne App for either IOS or Android.
