Ian
2
Hi Cay,
Welcome to the Cayenne community!
The short answer to your question is the DS18B20 address goes in the slave field.
or
Each 1-Wire slave device has a unique, unalterable, factory-programmed, 64-bit ID (identification number), which serves as device address on the 1-Wire bus.
The slave address for a DS18B20 looks like this 28-000006908c5f .
If Cayenne can’t ‘see’ the device you can use the below link to instructions to check to see if the RPi and 18B20 are working together.
Good luck,
Ian
