Deleting Widgets
It appears I have multiple phantom widgets on my Web browser that will not delete… I tried a reset of the dashboard but no luck… There are only on the left hand side under the device. I can not drag them over also…
Example… The Digital Outputs and heat on are not on my dashboard but they still show up.
this issue is known and the widget cannot be deleted from the left sidebar. If you device is new and not much of history data then you can delete it and re-add it again.
Can you delete a device and re-add it and keep the same MQTT username and password?
the username and password are always same, only the client_id changes. Once you delete the device you cannot have the same client id again.
