Sensor brought from MyDevices, but not listed in Cayenne as a supported sensor. Is there anyway we can get these sensors added?
You can add Dragino LDDS75 for time being, it will show the distance in place of the level.
Does Dragino LDDS75 work for you please?
Yes, it works. Can you try adding it.
Yes, I did. It only shows RSSI, SNR, and Battery voltage on Cayenne UI
but I can see the distance value in the TTN log:
Any advice please? Thank you.
can you share the Deveui.
sure, the DevEUI is A840415C5183969B.
we have fixed the issue, can you check now.
