After connecting TTN (LDS01 Door sensor) with Cayenne I can only see a Location field (screenshot 1). I’m missing all the other fields described in the Dragino manual (see second screenshot).
Already deleted and installed the sensor in Cayenne.
What can I do?
can you PM me your DevEUI.
There is no data received from this device. Can you check if you are receiving data on TTN console and make sure you have added the mydevices cayenne integration Cayenne Docs
That was the point! Now everything works as described! Thanks!
