GPS map not displaying correctly on PC
Have a node that sends GSP data along with other sensor output. Previously displayed normally. Currently shows world map with pin at what appears to be a correct location then looks like map zooms into a blue area with nothing there. Zoom in and out doesn’t appear to function. Data table shows normal / correct coordinates.
Sorry - just figured out that the first coordinates sent were bad - gps module may not have been connected to satellites yet. So first location was off the SW coast of Africa and zoomed in all of the way. Eventually figured out that I needed to zoom out all of the way and then could see history / trail that showed subsequent data points in correct location in NE USA. Not sure why the map is staying zoomed in on the first (incorrect) location.
can you delete the widget and let it re-add it again.
