Most of my sensor data will not graph if I request data longer than 1 hour as it says “No data available for this period” However, if I select 6mo, then it will graph data up to Feb 28 2023.
I’ve uploaded an example screenshot from DeviceEUI
A84041F851832EDD
but I have the sample problem with other sensors.
I’ve tried resetting the dashboard but it has no effect. I do find that I can download data to Excel in CSV format and graph that way, but it would be good to see daily / weekly graphs again as it use to work.
