I am working with ESP8266(wemos d1 mini).My example send temprature data and I can see temprature widget on my dashboard. However I can’t add any new widget or actuator my dashboard like actuator or custom widget. Here custom widget setting look like this.
Here my code:
//#define CAYENNE_DEBUG
#include <Wire.h>
#include "Adafruit_MCP9808.h"
#define LED LED_BUILTIN //On board LED
#define VIRTUAL_CHANNEL 1
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
char ssid[] = "xxxxx";
char wifiPassword[] = "xxxxx";
char username[] = "xxxxxxx";
char password[] = "xxxxxx";
char clientID[] = "xxxxxx";
unsigned long lastMillis = 0;
// Create the MCP9808 temperature sensor object
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
Serial.begin(115200);
Serial.println("MCP9808 TEST PROGRAM");
if (!tempsensor.begin(0x18)) {
Serial.println("Couldn't find MCP9808! Check your connections and verify the address is correct.");
while (1);
Serial.println("Found MCP9808!");
tempsensor.setResolution(3); // sets the resolution mode of reading, the modes are defined in the table bellow:
//Onboard LED port Direction output
pinMode(LED,OUTPUT);
if(millis()-lastMillis > 5000) {
lastMillis = millis();
tempsensor.wake(); // wake up, ready to read!
float c = tempsensor.readTempC();
Serial.print("Temp: ");
Serial.print(c, 4); Serial.print("*C\t \n");
Cayenne.celsiusWrite(2,c);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN(1)
if (getValue.asInt() == 0) {
digitalWrite(LED, HIGH);
else {
digitalWrite(LED, LOW);
CAYENNE_IN_DEFAULT()
