It is possible create business logic in Cayenne
It is possible create business logic in Cayenne ?.
I have and Arduino that read and sent data from 100km far away, many times i need go there to change the bussines logic.
It is possible change the business logic only on project with development language?
what do you mean by business logic?
I have an arduino that sends and receives data from Cayenne, I need some relays to be triggered according to some of the data values.
Example
if (temperature> 30 and humidity <20) {
trigger_engine = 1
The arduino will receive the variable trigger_engine and start the engine.
Did you try the trigger feature. You cannot have two condition like the one you showed above.
