Hm, that hadn’t worked before - but as we wrote, I noted that the internal temp sensor seemingly got updated, but the “old” data wasn’t available for some reason.
So I again deleted it and added it again, and now it works.
I have no idea why - I guess it must have been your good influence and maybe I made a mistake before…
I too am having this exact same problem and cannot find a solution.
There are two widgets (external temp and humidity) that show data when I click on the device, but for some reason will not allow me to add the widgets to the project.
I have tried dragging the device into the project then clicking the widgets I want and also tried to drag the widgets from the left pane into the project window, neither option has worked.
Any ideas?
